Removing the Radiator from an AC 180
WilliamP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamP Quote  Post ReplyReply Direct Link To This Post Topic: Removing the Radiator from an AC 180
    Posted: 30 Nov 2020 at 10:21pm
I have an AC 180 with a Westendorf loader and a Q1 year around cab.  Recently the radiator started leaking bad and I need to remove it and get it repaired.  Are there any websites with free manuals or videos on how to remove the hood and the radiator?  I'm hoping that I don't have to raise the cab to slide the hood our from under it.  Any help will be appreciated thanks much.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 10:28pm
The cab should have a small panel to remove on the front in order to raise the hood after unbolting it. Best to remove the radiator cap. Remove the air cleaner, and unbolt the radiator. You may have to remove one of the side panels in front from the support.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamP Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 10:40pm
Thanks much.  I have the tools and mechanical aptitude but haven't worked on this tractor before.  The loader makes accessing the bolts on the hood a pain.  I've been looking for a video on how to do it, but that seems to be the one video no one has made lol.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 8:41am
if the loader is a quick attach type,, remove it and get it out of the way
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 2:58pm
Unfortunately it is not a quick detach loader.  Since I cannot find a video of the radiator removal next best thing is to get a service manual.  Anyone have a link for a service manual for an AC 180 from a respected site?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 3:23pm
Changed radiator in my 180 with a 500 series loader hanging on it, left hood atop the machine just blocked it up over the engine, all hood bolts were removed and the grill and guard, radiator comes out the front.  Lower hose is a BEAR to get at to get clamp off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 6:06pm
Its really pretty simple, remove grille -air cleaner- hoses, jack the hood up a bit -it bolts to the front side shields, just becareful putting the new one in !
