Removed Hydro to install expensive AGCO seal |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Topic: Removed Hydro to install expensive AGCO sealPosted: 30 Aug 2018 at 7:10am |
Installing the hydro output seal in my L2 and that seal 71160387 was either $84 or $94! Didn't look special to me but I was in a hurry so it's in now. Also put in the input seal on the transmission just because I was already there and that was priced much much lower. Anyhow the bolt in frame under the hydro unit was busted loose when I took it off. Or I should say the plate it bolted to was busted loose. That plate had the crappiest factory weld I had ever seen on any piece of equipment. I took pics of that crap...... if I could figure out how to download them from my new phone, I would. Anyone seen that before? A break in that area? It's welded up solid now. I gotta say that was an easy job even with the welding.
Edited by Lonn - 30 Aug 2018 at 7:10am |
Wink I am a Russian Bot |
Posted: 30 Aug 2018 at 7:21am |
Might as well install a new drive coupler between the hydro output and the tranny input and never seize it liberally.
Lonn
Posted: 30 Aug 2018 at 7:40am |
