remote cylinder d series and older |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3797 |
![]() ![]() ![]() ![]() ![]() Posted: 26 May 2023 at 9:14am |
was there a remote cylinder offered as a accessory that you moved from impliment to impliment , i know alot of guys just one cylinder
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21416 |
Many only had ONE CYLINDER because that's what they could afford. Cylinder stroke length is always 8 inches, UNLESS it is something special and in that case you won't be using it on multiple pieces of equipment.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8502 |
Dad had one cylinder. Got switched around. Disc,combine,bar mower,drill etc. I think I have his plus 3. Two larger than the other two.
WD45 Aaron ![]() Bronze Level ![]() Joined: 03 Dec 2009 Location: Alto, MI Points: 127 |
Steve,
Any chance I could get you to run a tape measure on them? I am going to need to figure out something for the semi mounted plow I just bought. It's not there and I have no idea what it should be. If I have some dimensions of your cylinders I might be able to figure it out. Some useful measurements: center of hole to center of hole retracted center of hole to center of hole extended pivot hole diameter(s) What is the shape and dimensions of the cylinder mounting, both at the rod end and body Interestingly, Agco still has the parts breakdown for 70/80 series on their website. It shows the same style tail wheel as mine, but not the cylinder. |
Machinery rescue for all things rusty or broken. Current residents include 3-1/2 WD45s, Oliver Row 77 gas, 88 diesel, Farmall super C, parts C, two Cat D2's, Clark C500-80 forklift, and a sick Kubota.
yes that is just what i was getting at probley a single acting , so 8 in. x what bore and rod diamiter
I'll try to measure tomorrow. It's a clevis on both ends.Probably 1 inch wide inside using a 1 inch pin. Try to get more specific info. Low volume-high pressure which all AC's used back then. Lon (MN) or Paul B had some for sale a year ago or so. Somebody on this site did. Can text pics if you PM me a number.
Edited by SteveM C/IL - 26 May 2023 at 11:28pm |
The bore and rod are one in the same.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4941 |
there were a few different sizes. I have 2 different sizes loaded on the trailer to sell at the Madrid, New York GOTO. I also have a Allis Chalmers Hi-Pressure 2 way cylinder available.
