Rebuilt B Low Compression
iff7378 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iff7378 Quote  Post ReplyReply Direct Link To This Post Topic: Rebuilt B Low Compression
    Posted: 12 Oct 2015 at 6:39pm
I just finished a rebuild on a 1939 B with 3-7/16 overbore pistions. New sleeves, rings and all that too. The tractor runs quite well except for the occasional miss and is rather tricky to crank start (no electric start). I checked the compression and I've only got about 40 lbs in each cylinder. Any ideas why my compression is so low or things to try to see where im losing compression? The valves and guides are also brand new and I gave them all a good lap so they should be sealing well.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2015 at 7:11pm
Lapping is not a valve grind if that is what you are indicating that you lapped rather than grinding the seats. Lapping is a final mating surface polish after the seats are cut or ground. I spark all new valves on my valve grinding machine before installing. I never put a new valve in out of a package.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2015 at 7:23pm
It's pretty hard to get a good compression test on a crank-only engine. To get a good compression test, you should turn the engine over repeatedly with a good starter (which you don't have).
If everything is new, the valves are adjusted properly, and it seems to run ok, I'm betting compression is ok. My 39 (crank-only) B seems like it has very little compression when I'm cranking it (but it still wears me out when it doesn't start quickly!!!). Mine is a hard starting engine, too, which is why it usually gets towed.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 2:06pm
Yes, sounds like the compression test was done incorrectly. A proper test is done by putting the tractor in a low gear and towing it with another tractor or truck with the choke and throttle wide open, and having someone walk beside or get a screw in gauge.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 2:18pm
Check the timing and the magneto impulse timing. That can make a tractor very hard to start. A few years ago I was hand cranking a C and it would start when I would crank it very very slowly, but not if I cranked it at a normal speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 2:55pm
Quick check would be to put a little oil in a plug hole and rig a compressed hose to each cylinder. Set the pressure at around 100 pounds and listen for leaks with both valves closed. If you have pressure regulator start lower and increase pressure until it will not hold.
If the leak sound is in the exhaust below 80 pounds you have a bad valve seal.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2015 at 8:20pm
If it's a brand new overhaul, as you suggest, I imagine the rings have not seated in yet either, which will also drop compression some.
Still in use:
This page was generated in 0.035 seconds.
