Rebuilding gearbox |
rustyorange45 ![]() Silver Level Access ![]() Joined: 01 Sep 2013 Location: Vernon Co. MO. Points: 392 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Oct 2016 at 2:47pm |
I finally finished putting the gearbox to my model 184 rotary mower back together. New bearings, seals, and gaskets. It turns smooth, but a lot harder than I think it should. I started it up and mowed my fence row, and when I was done the gearbox was too hot to touch. It still turns smooth and doesn't make any noise. Will it run cooler when the bearings wear in? Anyone with experience of this? Thanks!
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8452 |
Do you set bearing pre-load on these? I wouldn't think so(I would think they would be sealed) but if so, they might be too tight.
If they're sealed, unless something isn't lined up just right and is causing more friction, I wouldn't think it would get too hot. My brushhog gear box gets pretty warm, but not that hot. It's a TSC brand. Edited by CrestonM - 12 Oct 2016 at 2:59pm |
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6422 |
X2, sounds like the bearings are too tight.
Gary(VA) ![]() Silver Level ![]() Joined: 13 Sep 2009 Location: Troutville, VA Points: 338 |
Did you make sure the gears have backlash and aren't too tight? Are there shims that can be installed or removed as needed?
Leon n/c AR. ![]() Bronze Level ![]() ![]() Joined: 19 Mar 2013 Location: Heber Springs A Points: 175 |
On my Howse brand hog you add or remove paper gaskets on the input side to preload brgs and gears. Leon
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5033 |
How did the bearing bores look? If the bearings go in a little off you can still get the shaft in but you'll have more pressure to one side and cause excess friction
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
How full is it on oil? Overfilling will cause a gearbox to excessively heat.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
How big is the cutter and much HP is on the front? MACK
The bottom shaft is where it is tight. The bottom bearing is pressed on to the shaft to the stop and I pushed the top bearing down the shaft into the race and then pushed the gear onto the shaft. At this point it was tight. I had packed the bearings with wheel bearing grease. When I put the top of the gearbox together it spun easily and I used the shim gaskets to get my gear backlash right. I filled with 2.5 pints of 140 weight gear oil as per owners manual. It is 7 foot pull type mower pulled by a WD45.
