rebuild question
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: rebuild question
    Posted: 06 Aug 2012 at 8:35pm
anybody know the best way to degree a cam gear? LOL sorry, I can't help meself
seriously, the sealing surface where the sleeve O rings will live has some serious pitting, looks like the lower ring will be OK, but, measuring down from sleeve seat it looks like the top rings are going to be either just below or right on some pits
anybody see this before and how did you fix it? sealer? epoxy? liquid metal?
Edited by LouSWPA - 06 Aug 2012 at 8:36pm
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 10:11pm
I'll stay away from the first question cause "I have trouble finding TDC"LOL
If an epoxy is the answer, I would think a little work with a brazing tip might cook any residual oil out of the iron so it would stick good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 10:42pm
actually, that gives me an idea....I wonder if i could lead it in and dress it
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 11:34pm
Right or wrong,I JB welded some spots on my Cat truck engine last time around. 480000 some miles ago
JoeB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 5:23am
I second JDWeld. Good luck.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 6:51am
Cut another oring grove between the 2 and put in the 3rd oring or machine the block at bottom and sleeve the area.  MACK
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 7:09am
JB weld will not stay in.  MACK
wi50 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 7:21am
For the cost of doing this machine work why not get another block? Your old block has good value as some tractor puller will bore it larger anyway. I've got good blocks on the shelf and would trade you but shipping would make it no value.
To do it right it really needs to be bored and sleved. But I have used a product called RocBlok from Competition Products in Oshkosh Wi. It's a fiber based block filler and works great as a sealer vs the grout based fillers. Assembling the liners as normal and an inch or two of this would seal as long as you have the block clean.
This page was generated in 0.039 seconds.
