Rebuild gasket set for CE motor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Rebuild gasket set for CE motor
    Posted: 01 Sep 2012 at 9:45am
Most sets i have received have cork valve cover gaskets. Several years ago i got a set that had a rubber gasket. Anyone know who sold that, or if some sets (today) are better than others ?
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 10:50am
Felpro sells a neoprene valve cover gasket.  I don't know the PN though.  I like it better than the cork gaskets because the cork breaks down and leaks by the manifold because of the heat.
Life is what happens while you are making plans for the future
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 11:17pm
FelPro and AGCO are two sources of the rubber gaskets.  I'm guessing that FelPro makes the gaskets for AGCO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2012 at 6:33pm
The FelPro neoprene rocker arm cover gasket I used on my 52 B was Part # VS 3708 R and included were the gromlets for the bolts used tightening.  Hope this helps.
