Reassembling shift tower, WD45 |
Manure Queen
Topic: Reassembling shift tower, WD45Posted: 23 Sep 2012 at 8:53pm |
Pulled the shift tower with gear in reverse to have some machine work done, now putting it back in, worried that I haven't got forks it seated right. Tips, tricks?
Flint23
Joined: 31 Jan 2011 Location: New Haven In Points: 429 |
Posted: 24 Sep 2012 at 2:55am |
Man, it's been awhile since I did mine, but I think it needs to be in 2nd gear to put it back together...
been there done that, not doing it again...
B26240
Posted: 24 Sep 2012 at 7:20am |
Sometimes it takes a couple trys, after install put just two bolts in and try each gear- you can tell if it's in gear by rocking tractor back and forth then shift to newtral and try and see if it will roll. Do this in each gear before you put all the bolts in and stearing shaft support. HTH
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 24 Sep 2012 at 10:54am |
Everybody has their own opinion, but I find it easier when it is in Nuetral to drop the shift tower in.
WEL(IN&TN)
Posted: 24 Sep 2012 at 11:29am |
Done several of them, neutral works best for me.
Manure Queen
Posted: 24 Sep 2012 at 11:39am |
Thanks very much. This is a stupid question, but does this entail manually moving the gearing into neutral before setting in the forks? I assume that's what you mean. Can you tell that this is the first time I've ever done this? I think I had it in reverse to remove it as that was the easiest to get it out. Putting it back in is another story! Thanks for everybody's help. I'm brave because of I know you're out there! |
Manure Queen
Posted: 30 Sep 2012 at 9:57pm |
OK, put it in neutral and tried to drop the forks into their grooves but it's tricky. Is there a best order to slip the forks in or just do your best to line them up? Easier if I stand on a particular side? Every time I think I have them set correctly, the tractor doesn't seem to want to go into gear easily.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8702 |
Posted: 30 Sep 2012 at 11:32pm |
You may well not be able to shift into all gears even when installed correctly.The chance of every slider being lined up with corresponding couplings is not very likely. Rock the rear wheel alittle while trying each gear. If you lock in the hand clutch and it goes in gear,you won't be able to move it. It will roll only in neutral.
