Rear wheel weight bolts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Rear wheel weight bolts?
    Posted: 13 Feb 2012 at 9:50pm
Does anyone offer the rear wheel weight bolt for the pie weights on a D17IV,170-175? I need a set. Thanks Tracy Martin
Crowman17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crowman17 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 7:47am
I got mine at the Massey dealer had all sizes.
Marc
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 8:02am
I have made them from carraige bolts available at most farm supply stores. Drill a 1/8" hole thru the bolt just below the square shoulder for a cotter pin. I think the D15/D17 use a 3/4" dia bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:30am
Agco dealer says 103.85 each. That is just a little too much. Crowman, where is your dealer? Thanks Tracy Martin
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 10:06am
I'm with Greg....too easy to make your own.
ALLIS EXPRESS!
This year:
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 10:22am
They are just a 3/4" carrage bolt with a 1/8" hole drilled in them for a cotter pin. To hole them in place on the wheel center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 10:25am
I wouldn't think they would be a carriage bolt, doesn't seem tough enough. Easy to make if they are though. Tracy Martin
