Rear wheel interchangability D series to JX95 ???
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Rear wheel interchangability D series to JX95 ???
    Posted: 09 Aug 2017 at 4:29pm
Does anyone know if the case JX95 and New Holland TN75 type tractors has the same rear wheel bolt pattern as the D series Allis tractors with 8 bolt rear wheel ?
Edited by Macon Rounds - 09 Aug 2017 at 6:27pm
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 12:29am
I don't know about D17, but I would bet they are close to 6060-80 dimensions.
I believe Eldon (WA) put wheels from a 6080 onto a 175 with a little bit of hand grinder work.
Edited by Nathan (SD) - 10 Aug 2017 at 12:31am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 1:16am
Don't the New Holland tractors use the Fiat pattern like on the Longs and Olivers like the
1365? The pattern is just a little off the US built 8 bolt pattern.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 6:34am
The standard bolt pattern is 8 lugs on 8 in. bolt circle. This applies to most tractors with 8 lugs. I have a 180 with Ford/NH wheels. The main problem is the lug holes are much larger than the Allis Chalmers centers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 9:02am
Thanks for the replys information...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 11:06am
Pretty sure the NH tractors being sold today do not have the exact same 8 lug pattern as the Fords did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 9:14pm
Which size tractors are you talking about? He's talking about 75hp tractors.
