Rear tire won't center
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Rear tire won't center
    Posted: 08 Oct 2011 at 2:10pm
Got one of the rims back (the worst) and it's beautifully repaired, but I can't get that damned tire to center. I've got it on the rim, with the tube, but I air it up and The bead won't stay centerd? Any ideas?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 2:43pm
I really don't want to say this, but is the rim round? I'd measure across it three or four times just to make sure.
Have you lubed the bead with anything? Soapy water will work to let the tire slide a little easier. Sometimes we used to have to smack the tire with a sledge to get it to slide into the correct spot.
Watch your air pressure, don't put too much in.
Good luck, I don't like messing with tires anymore, but for the price the tire shops want...
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 2:45pm
Yes, it's round. I measured 6 times on both sides. The tire wants to sit higher on one side than the other. I used pure dish soap on the bead.
German Shepherd dad
#WD234847
#WD88193
Tony Elo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Elo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 3:10pm
are you trying to inflate it standing up? I would lay it down, put lots of lube on the beads like you did and make sure the rim is centred in the tire before you blow it up,good luck hope it works for you,tony
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 3:13pm
Tony is right, however if you already are trying it laying down, then I would mount it on the tractor, and put the side that wants to seat first down, then lower the tractor just enought to coax the opposite (top) side to seat first, then the bottom may come on like normal.  The only other thing I can think of is when they repaired the rim, the rim "grew", it won't take much, the steel belts in these tires, do not strech much if any at all.
Edited by Orange Blood - 08 Oct 2011 at 3:14pm
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 4:01pm
Heres some pics of the rim repair, Before and after
Last March when I first got it off
Repair made:
German Shepherd dad
#WD234847
#WD88193
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 4:03pm
I agree with Tony I tried to install one dry once and had the same trouble, try more lube and as Tony said make sure its centered HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 4:16pm
This is what it's doing:
German Shepherd dad
#WD234847
#WD88193
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 4:25pm
Wack it with a good sized hammer after you have it aired up.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 5:50pm
I use cheap grease on the tire and wheel and have good luck. Also as RW says start wacking the unseated part of the tire  and it might help. This may not be a good idea but one time I had one on a D14 do the same thing so I put it on the tractor and went for a drive and it was seated in 20 feet
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 6:18pm
I'm with Thad. I put a pair of ag tread tires on my garden tractor once. One of them wasn't quite seated properly, but after driving it the tire set up perfect. My tire wasn't nearly as far off center as yours is, however.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 6:32pm
Got it set. Aired it down, filled it and beat it a few times
German Shepherd dad
#WD234847
#WD88193
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 4:08am
I was going to post using wood or something to protect the rim, and hit it hard. Or try hitting the tire to shock it to seat.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
