Rear tire fluid options |
roscoe ![]() Bronze Level ![]() Joined: 30 Oct 2009 Points: 37 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Feb 2012 at 7:14am |
After reading the posts about the low-hour 7080 and the possibly rusted/replaced rear rims, I was reminded to ask folks about options for rear tire fluid.
I ran a 3/4" bolt through my D17 rear tire last fall, and had that one side replaced, but did not put the chloride back in, since it is also showing some corrosion at the fill valve.
Now, of course, that tire loses traction and spins all of the time.
Are there any non-corrosive fluids, that you can actually afford?
I thought about RV antifreeze, (the pink stuff) but don't think that I want to pay for it.
thanks,
Roscoe.
kschab92 ![]() Silver Level ![]() ![]() Joined: 31 May 2011 Location: Illinois Points: 106 |
This stuff works pretty good I know. It stinks but is 28 cents/lb.
Brian S(NY) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3380 |
around here folks are using windsheild washer fluid.
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Replacing the valve cores every 2 years on CaCl filled tires will go a long way to preventing any leaks. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I do what Mike does; new valve cores every 2-3 years or at the 1st sign of leakage. Jack up that side, rotate tire so that valve stem is at the top and carefully remove it. I also coat the threads with vasoline before I install the new ones. Doeds not do much good if one runs a bolt or ??? into the tube tho.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
jmikeyoung ![]() Bronze Level ![]() Joined: 10 May 2011 Points: 42 |
i've heard of some beat juice stuff
D17 owner ![]() Orange Level ![]() Joined: 03 Jul 2010 Location: ladysmith Wi Points: 225 |
The beat juice stuff is rim guard. I looked into it and it was a no for me. The stuff will freeze on you a tire shop told me. They USE to sell it and not no more. They said you needed bigger pumps to pump it. and here in northen WI they said it turn to like a slushy. They said it took them all day to change one tire because of that. But it wont rust the rim. Just about 4 bucks a gallon to. Eric
cobra ![]() Silver Level ![]() ![]() Joined: 16 Oct 2011 Location: p.e.i. canada Points: 66 |
can u load tubless tires
TexasAllis ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: Texas Points: 396 |
1944 Allis C
1960 Allis D-17 LP |
