Rear rims for D12 III |
Marlyn nwia ![]() Silver Level Access ![]() Joined: 11 Sep 2009 Points: 395 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Nov 2015 at 1:03pm |
Which combine rims fit a D12 III? 12"or 13" wide X 24"..... 4.75" center hole with 6 lug bolt holes?
Marlyn |
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
If a D12 has the same 4.75" center hole 6 bolt hole as a D10 or my CA. Stamped Farmall A or B wheels will fit.
I run 13.6 24 rubber on 11x24 rims on my CA. using Farmall centers which are the same center as a D10. I have a pair of 13.6x24 almost like new Goodyear Dyna Torque II 8 ply and tubes takeoffs and a set of JD 11x24 rims for sale. See my add in the Classifide forum for pictures. They would look great on your D12 If you use the Farmall wheel centers like I did. Farmall wheel weights fit perfect Edited by Ken in Texas - 21 Nov 2015 at 11:50pm |
My CA with 13.6 X 24 Firestones on 11" MF rims on Farmall A steel wheels with Farmall A weights
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54153 |
I have a set of "temporary" rims on my D-10III, centers are farmall, rims are british leyland... Had to blow about 1/8 inch off the outside of the center to rim holes, with the plasma cutter, to get them to fit. Could've done it with a file, but the PC was less effort...
