Rear rim valve stem blank needed-6060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Rear rim valve stem blank needed-6060
    Posted: 19 Jun 2021 at 8:10am
Got a 6060 with the rear rim valve stem has rotted out and I don't have any junk rims to cut pieces out of question is- does any rim mfer sell a blank or piece that I can weld in?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 8:31am
Is it a 28" rim?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 3:00pm
Yes it is, the simple just plain steel deal ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 6:01pm
5/8 flat washer. Once again it's not If your rim will rust out from calcium filled tires but WHEN Dead
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 6:37pm
Yeah Its not that simple , theres about a 12 inch section that has been abused, thats why i need a piece of rim , not a washer
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 6:37pm
Doug, you might check with your local welding shop. When I first started in the farm tire business, our local shop had the blank holes to weld in your rim. I had several done. Almost impossible to tell they had been repaired.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 6:43pm
Ill do that , thanks Tom
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 9:41pm
I had my local welding and fab shop fix holes that size on the rims of my D17 diesel.  They welded in new metal and drilled a new hole for the valve stem.  Put a little bit of body fill on the outside to smooth things out, primed and painted and you cannot see any evidence of any work or damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2021 at 9:45pm
The rear rims I look at have a "pocket" for the valve stem to sit inside. It is stamped into the rim from the inside swelling it outwards. Hard to duplicate in my pea-brained way of thinking.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2021 at 5:33am
I patched one on the 170 using a piece from the WD that is beyond repair. After welding in the patch I then heated the area for the valve stem and used some flat stock as a form to hammer the shape. Then drilled the hole. Seems like someone here had die made? Not entirely sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2021 at 7:17am
Maybe able to use flat steel and fabricate it enough to seal it up smooth it out and redrill, thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2021 at 7:55am
Here's a thread I did last year;
https://www.allischalmers.com/forum/rim-repair_topic167543_post1403468.html?KW=rim#1403468
Some of the pictures are missing. Here is one of the flat for the valve-stem. Heated the area and hit it with a 4 lb. hammer. Had it on the horn of the anvil at the time. Not perfect but did the job.
Still have pieces I cut out of the junk rim to make patchs, would give you one if you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2021 at 9:57am
Ill keep that in mind Mike , thanks ill try to get some pics of what im doing , but its just like what youve done is what i have in mind
This page was generated in 0.110 seconds.
