Rear inner weight question |
randy
Joined: 12 Sep 2009 Location: Illinois Points: 1226 |
Topic: Rear inner weight questionPosted: 17 Dec 2020 at 6:24pm |
How much could inner weights for 38 inch castings weigh?
DougG
Posted: 17 Dec 2020 at 6:30pm |
Ive heard 1400 lbs,,, those are monsters, sorry thought they were the big dudes,, pictures were hard to tell,
Edited by DougG - 17 Dec 2020 at 7:35pm |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8749 |
Posted: 17 Dec 2020 at 6:47pm |
mine are only 2in? thick...seen a lot thicker ones....don't know how many variations there are
randy
Posted: 17 Dec 2020 at 7:12pm |
I think these are 2 maybe 3 inches thick, and 31 inches wide
randy
Posted: 17 Dec 2020 at 7:13pm |
My 7060 and 8050 have 2 on the inside
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 17 Dec 2020 at 7:20pm |
cast weighs about .284#/cu in or 491#/cu ft so... figure out the volume of the weight.. measure then subtract 'hole' from total.. all I know is my back hurts just LOOKING at them !
Posted: 17 Dec 2020 at 7:26pm |
400 lbs each.
randy
Posted: 17 Dec 2020 at 7:30pm |
Thanks Dr
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3604 |
Posted: 17 Dec 2020 at 9:24pm |
What was the usual installation for these inner rear wheel weights? Factory installed? Dealership installed? Field (on farm) installed?
If weights were not factory installed onto tractor, how did truckers usually secure them to their trailer for transport from factory to dealership ? Metal crate? Wooden crate? Etc...?? |
LionelinKY
Joined: 12 Sep 2009 Location: Radcliff,KY Points: 698 |
Posted: 17 Dec 2020 at 10:54pm |
You say 31" wide which I assume to mean diameter?? Would these same weights have been used on a 34" wheel too?? Our 1966 190XT has 1 inside each rear wheel with the 6 pie weights on the outside of each wheel too. We are the 2nd owners and bought it as is in 1970. Local dealer sold it brand new and Dad knew the original owner. Tractor was ordered that way due to the very hilly fields that were on the guy's farm. He wanted it heavy to pull/hold on his hills.
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2319 |
Posted: 18 Dec 2020 at 9:00am |
I think that is the same weight I had on my D21, had three on each side, when I traded for 7030 the dealer took them off and put 2 on each side of that. Dr knows but my dealer called them 450 lbs.
