Rear End Sight glasses? |
| Author | |||
Roscoe62
Joined: 22 Aug 2014 Location: Louisville Points: 145 |
Topic: Rear End Sight glasses?Posted: 07 Jun 2017 at 1:26pm |
Is there a good place to get these sight glasses? I have one that is loose and won't tighten.
- Roscoe.
| Sponsored Links | |||
Dans 7080
Posted: 07 Jun 2017 at 1:58pm |
Agco had them a few years ago. They take an o-ring to tighten and seal.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
shameless dude
Posted: 07 Jun 2017 at 5:04pm |
yep....replace the o-ring and you should be good to go!
Joined: 11 Sep 2009 Location: illinois Points: 89279 |
Posted: 07 Jun 2017 at 7:46pm |
is this a button glass that fits in a pipe thread hole ? Aftermarket has 1/2- 3/4 - 1 inch etc
Edited by steve(ill) - 07 Jun 2017 at 7:47pm |
Roscoe62
Posted: 08 Jun 2017 at 4:34am |
Glass threads are stripped. I'll check AGCO.
Thanks all, Roscoe.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 08 Jun 2017 at 7:52am |
minnpar.com has them for $16.28. I got some from a salvage yard.
corbinstein
Posted: 09 Jun 2017 at 7:06am |
So do the sight glasses help you check out Rear Ends?
Couldn't help myself....
Lonn
Posted: 09 Jun 2017 at 7:22am |
sight glasses for rear ends.............how about fronts
Wink I am a Russian Bot |
LB0442
Posted: 09 Jun 2017 at 9:30am |
Here's what I have found with the sight glasses over many years of work on equipment. In the picture the ones on the left are GM #12475420, they were used for radiator sight glasses in heavy GM units. The problem with those is they are plastic and over the years they turn white, the replacement has a brown color to it and seems to last longer. Problem with that is hard to see light oil in it. The middle ones are AGCO #70265359, glass but the threads do go bad if over tightened. The one on the right are Case/IH # 427708C1, same as AGCO, mostly found in school bus units. All of them have the same threads, I like the plastic ones to have around in case I break one or one falls out in the field. Glass is the best for visibility but the plastic has more threads.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8749 |
Posted: 09 Jun 2017 at 12:55pm |
It doesn't take much for tight to keep them from leaking with the oring.Too many think they must be TIGHT! and that's what kills the threads.
