Rear end oil for D10 SII
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Rear end oil for D10 SII
    Posted: 29 Jul 2017 at 5:32am
Quick question regarding the rear end oil in a D10 Series II.  I'm at the shop and my manual is 30 miles away at home.  What weight oil do you use in the rear end of a D10 series II?  Also is it detergent or non-detergent?
Thanks,
snowman(MI)
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 5:40am
Universal transmission/hydraulic oil.  This is really 20 weight non-detergent oil.
indiana2door View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote indiana2door Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 9:56pm
Non-detergent oil should only be used to lubricate door hinges. I use CIH Hytran in my B. D10 takes the same.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 3:27am
Definetly use a Non-Detergent oil. The rear differential is the Oil Reservoir for the hydraulic system.
Gary
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 5:01am
Quote Detergent or No Detergent
DIN 51524; HLP-D fluids are a class of antiwear hydraulic fluids that contain detergents and dispersants. The use of these fluids is approved by most major hydraulic component manufacturers. Detergent oils have the ability to emulsify water, and disperse and suspend other contaminants such as varnish and sludge. This keeps components free from deposits, however, it also means that contaminants do not settle out - they must be filtered out. These can be desirable properties in mobile hydraulic systems, which unlike industrial systems, have little opportunity for the settling and precipitation of contaminants at the reservoir, due to its relatively small volume.
The main concern with these fluids is that they have excellent water emulsifying ability, which means that if present, water is not separated out of the fluid. Water accelerates the aging of the oil, reduces lubricity and filterability, reduces seal life and leads to corrosion and cavitation. Emulsified water can be turned into steam at highly loaded parts of the system. These problems can be avoided by maintaining water content below the oil’s saturation point at operating temperature.
So as I interpret this you can use detergent oil if you have a good filtration system. Otherwise stick with non detergent.
Edited by DougS - 31 Jul 2017 at 5:04am
This page was generated in 3.465 seconds.
