RE: Weights
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Topic: RE: Weights
    Posted: 24 Sep 2018 at 8:28am
  Howdy,
  What is the weight of the starter weight on a one seventy?
  Thanks Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2018 at 8:51am
I always thought a 180-190 starter weight was 250 lbs. The 170 is a bit narrower at the side frames, so I assume it is a different part ??   Been too long ago to remember for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2018 at 9:00am
I was thinking 275 pounds IIRR. They are all one person wants to handle. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2018 at 1:37pm
   Howdy Tracy,
   All one man wants to handle!!!  275 lbs. I weigh half that!
   Thanks Much
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2018 at 6:36pm
Finally remembered to look this up in my old collection of advertising literature. The big starter weight was called 280 lbs and the smaller add-ons were 75 lbs each.  The 170 starter weight must be the same as a 180-190 because they weigh 280 lbs also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2018 at 7:06pm
    Howdy DrAllis,
    Wow ! Thats no one man job. Looked at a one seventy with starter weight and did not look 280 pounds. But I got all weights coming will find out!
Thanks Kurzy
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 7:26am
I am sure it would NOT work but if you used 2-2"x6". Run them from the tailgate of your GMC to the front axle of the tractor. Could you slide the weight over and be the right height to mount the weight?
Nah, CAT forklift would be my tool of choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 8:05am
    Howdy Unit3,
    Thanks for the idea But paint first!
    Kurzy
This page was generated in 0.119 seconds.
