Rattling noise in engine of D17, series3
Kruger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kruger Quote  Post ReplyReply Direct Link To This Post Topic: Rattling noise in engine of D17, series3
    Posted: 25 Apr 2025 at 7:39pm
Today, while the tractor was idling, I noted a rattling noise from the front of the engine. It appeared to originate near the belts. It appeared that the belt appeared to stretch and contract while the engine was running. The belt to the alternator did not appear loose. Due to a time constraint, I did not look further. I had the engine rebuilt last year. Let me say that I am no a mechanic. Any ideas of possible causes. Thanks for whatever help you can provide.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 7:48pm
Get a good hold on the fan blades. Wiggle back and forth to see if any play in water pump. Do the same with generator or alternator.
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 8:09pm
Possibly the soldering broke loose on fan shroud and fan blades are contacting loose shroud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 8:29pm
Water pump. Generator bearing. LOOSE CRANKSHAFT PULLEY.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kruger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 9:08pm
Thanks gentlemen!
only AC orange View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2025 at 8:56pm
I vote for the loose crank pulley! Many years ago, my set. III had a rattle noise, sent it to dealer for repairs expecting serious consequences - hauling bill was lot more than bill to tighten the set screw!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kruger Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2025 at 6:25pm
As an update, I checked the water pump, power steering pump, and crank shaft pulley. All appeared OK. I really did not check the belts closely, and surprise the deflected at least an inch. So tightened them up and noise gone. Thanks again for all the excellent advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2025 at 9:16pm
Glad it was that easy. You got some good advice that paid off. Thanks for letting everyone know your findings.
