Random Hydraulics Question...
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Topic: Random Hydraulics Question...
    Posted: 27 Dec 2020 at 10:25pm
I have a homemade snow plow for my C that uses the factory hydraulics to lift the plow.  Not being able to lift with the trans clutch pushed in isn't ideal.  This has caused me to ask the question, what is the first similar sized AC tractor with hydraulics that would allow me to lift the plow with the trans clutch pushed in?
Thank you in advance,
Ben
Leave things better than you found them.
1941 Model C (restored 2020)
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 10:42pm
 I believe the CA is what you would be looking for, although the WD also has the live PTO.
 You could also look at adding a pump at where the hand crank goes for hand starting your C.
 Dusty
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 10:58pm
If its 12V you could get a electric over hydraulic unit to raise and lower the plow.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 1:29am
I think the answer to your question would be the 720 in ‘73. It has about the same hp but is a hydro. As for actual “power” comparison I would say the 5020 when taking into consideration the torque and to get a gear transmission. They came out in ‘77
The wd and ca don’t have true live hydraulic. They have a hand clutch to stop power after the trans and hyd pump. The question you asked made me think about it a bit and had to reference tractor data to confirm!
Edited by im4racin - 28 Dec 2020 at 1:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 6:31am
I'm with Gary, buy/install a 'snowplow pump' unit. Up here about $300 when on sale. Makes for a clean,easy install , reliable,easy to use. Has to be cheaper than buying another tractor that has 'live' hydraulics and installing your blade onto it.
Your C will need to be 12 volt, alternator and a GOOD battery ( 2 is better).
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 6:55am
The D10 & D12 tractors had true Live hydraulics starting in 1961.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 8:26am
electric add on is probably the cheaper route.. But im with Paul... D10 - 12 or would be very nice unit.
Edited by steve(ill) - 28 Dec 2020 at 8:26am
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 8:46am
WD gives you live hydraulics when using the hand clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 8:49am
 I have a 720 with a loader that I like, and like said it has a hydro transmission, it also has a cat-0 3-point.
 It's classed as a garden tractor, and has an air cooled engine.
Dusty
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 10:13am
You'd probably be happiest with a 5020, but you're better off to stay away from the 4wd version.  The front drive seems to be a weak link and parts are not available.  A 5020 with ag tires and chains would do what you want but like any other tractor used for what you want, would need some rear ballast.  Loaded tires or wheel weights.
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 5:41pm
If you’re satisfied with the way the C works the plow other than live hydraulics, just add live hydraulics. You can get an electric set up as suggested here or put a pump up front at the hand crank location, or add a power steering pump from an older Chevy and run it off the engine. I’ve seen it done, by double pulley on alternator or remove generator and mount there, and just keep battery charged when not in use. A good 12 volt battery will start and run that C a very long time without being charged every day.
Or I agree with a 1961 D-10 or 12.
I have a 61 D-10 with live hydraulics and it is a lot handier than a C and a good bit more horsepower also, and a lot of them came with 3 point hitch which is nice now a days and could put a back blade on it.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
This page was generated in 0.766 seconds.
