Radiator Recore |
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10360 |
Topic: Radiator RecorePosted: 08 Jun 2019 at 10:33pm |
My 1962 D-17 (gas) radiator has some leaking tubes.
How much should it cost to re-core the radiator? |
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 314 |
Posted: 08 Jun 2019 at 11:15pm |
I had mine done last winter. I think it was almost $600.
Clay
Posted: 09 Jun 2019 at 10:36pm |
D-17 gas Radiator part #70229702
I have seen new radiators range from the mid $400 to over $800, on line. Several of the vendors on here have them for a little under $600. I may try to patch it myself. If it does not last then I will seek out a professional radiator shop.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12394 |
Posted: 10 Jun 2019 at 7:43am |
Clay, can you actually get that part number? I tried to get one for me 7045 a few years ago. An Agco dealer showed the number, but showed as back ordered. I ended up doing a recore.
TimNearFortWorth
Posted: 10 Jun 2019 at 11:41am |
If you don't have a reputable shop near enough to re-do, Tony with Tony's Tractors can likely get what you need. He is well versed on inlet/outlet, neck heights and any side bolting for original cowling as he has been in this for quite some time.
Advertises on this site and competitive pricing to boot.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2885 |
Posted: 10 Jun 2019 at 1:51pm |
Take it to a competent honest radiator guy he’ll either fix it or tell you to replace it. When I drop off a rad he calls with a quote to fix it and asks if I can find new cheaper never once have I found new or reman cheaper than him recoring it. Certain point you have to pay to play
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 11 Jun 2019 at 6:57am |
Some of the new ones leave a lot to be desired
Wink I am a Russian Bot |
frnkeore
Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
Posted: 11 Jun 2019 at 11:31am |
Are all the options copper core or are there aluminum cores with composite tanks available?
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
Clay
Posted: 14 Jun 2019 at 9:43am |
$600 for a new radiator. I thinkI am going to try to cut out some of the fins and use epoxy to seal the leak. I have done it on big, heavy equipment, radiators.
Once repaired a hole in a Mercedes diesel radiator. That hole was 1/4" x 1" in the bottom of the tank. At this point in the game, I think I will spin the luck wheel.
DougG
Posted: 15 Jun 2019 at 9:01am |
Give it a whirl , should work , ive done a few
