raddle chain installation tips |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3631 |
Topic: raddle chain installation tipsPosted: 24 Nov 2016 at 5:41pm |
I never saw the sprocket idlers for the short raddle... 71160426 is the #, anyway loosen the bottom and pullit all the way back, the chains used to come with S pins for the master, for a very good reason . Check the front drive sprockets as well. After installation
tighten the chain so as to have to push hard to move the chain on the sprockets. After 8 hours of operation it will have to be tightened again , It is imperative to keep this chain tight, other wise backfeeding will bend and break the chain, . Make sure the anti backfeed fingers are in place and just miss the back raddle.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8971 |
Posted: 24 Nov 2016 at 9:43am |
I remove the cover at front of raddle on my F2 and blow it out while running. Lots of trash to collect moisture in there.
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 24 Nov 2016 at 1:29am |
the grain machines have a flat idler with a guide lip that goes to the outside.
The corn soybean machines have a sprocket idler. Either will work, just make sure to use a matched pair. It sounds like they might have tried giving you a plain chain idler with no shoulder? Do you take the cover off in the off season? IMO leaving the cover on is the leading cause of raddle chain failure. leaving it on causes rusty links, which cause future failure IMO. |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2375 |
Posted: 14 Nov 2016 at 8:43pm |
grinder220
Posted: 14 Nov 2016 at 3:17pm |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8471 |
Posted: 14 Nov 2016 at 1:34pm |
Well...if the old one was still in, I'd connect the new one to the old one, then pull the old one out. That way it will then pull the new one in! Then just disconnect the 2, and hook the ends of the new one together. Bingo! Done.
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 597 |
Posted: 14 Nov 2016 at 11:24am |
You will need the rope or ropes and a long stick to guide it..good luck..a bucket full of cuss words might also help...Make sure not to put it in backwards..Mark
Posted: 14 Nov 2016 at 10:48am |
Be sure to replace to idlers up at the top.
zulawski87
Posted: 14 Nov 2016 at 10:18am |
I ran rope around and pulled it up and back down. Easier with two ppl to keep things straight and not catching on something
grinder220
Posted: 14 Nov 2016 at 9:28am |
The ol'M2 chucked the front raddle chain on me yesterday,ended up getting its little brother the F out so I could keep going. Any tips or tricks on getting the new one put in? It doesn't look like its that big of a job but I have heard people say it's a real pain. The old chain is out already.
