R62 rotor gearbox
weedeaterlt85a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weedeaterlt85a Quote  Post ReplyReply Direct Link To This Post Topic: R62 rotor gearbox
    Posted: 26 Oct 2017 at 9:18pm
Can the R62 rotor gearbox be removed without first removing the rotor?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 9:59pm
no. bolt heads are inside...
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 10:00pm
I don't think so. Bolts the remove box are from inside the cage.
ryan
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 8:21am
Unless there is some trick we didn't know about, be prepared for battle.  It is one heavy sob and not easy to finagle it down out of there.  or back in
Edited by CAL(KS) - 27 Oct 2017 at 8:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 9:57pm
there is a door right above it - a hoist or come=along hooked to a bar above the box on the grain bin top makes it easier - DO NOT FORGET THE GEARBOX IS SHIMMED - MARK THE SHIMS AND PUT THE BACK IN THE OEM LOCATIONS OR ELSE THE SHAFT WILL NOT LINE UP WITH THE FAR END BEARING.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 8:41am
A forklift would make the job easier. When I worked at west plains imp, I pulled lots of rotors, and a fair jag of gear boxes. Me and a co-worker who had plenty of experience, start to finish, had a rotor setting on the ground in 9 minutes one time. When it come to pulling gear boxes, I made a pole that I put on one forklift tooth. Had to get it in at just the perfect position, and it could be brought right down and out. Pull out the oil fill plug on the top of the gear box, and weld a ring onto it, and re-install it, and use that for a lifting point. Darrel
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 8:15am
We just finished putting a new gearbox in the R62 , I did not remove the rotor opened the cage got the back bolts out cover on side of combine to take off got a few more ,opened rock door and got the rest from going up inside from the bottom. And it really helps if you can find a skinny young guy to go up inside from the bottom! It can be done ,we just did it.
