R62 fire unexplained>
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: R62 fire unexplained>
    Posted: 23 hours 9 minutes ago at 7:34pm
Raining here today so getting a break to catch up and take a breath. Last Saturday, I had a wedding to go to so my son was cutting beans without any one around. I trust him more than any 25 year old I know, he is very mechanically inclined. He cut around the field, turned around to head back and smelled smoke in the tail wind. He found a 3 foot fire right at the driver side rwa drive motor (where all the chaff rests). Had an extinguisher mounted a foot from the rear entry ladder, he put it out. Burned the covering off the rwa hyd lines under shoe above rear axle. But nothing else looked hurt. We thought maybe the rwa motor or solenoid got to hot or sparked. Next morning we found burn spots a couple of feet in diameter in the area he cut for a long ways. So we decided to leave rwa off. But had no idea how it started, that's a sick feeling. That was Saturday at 5pm we cut beans all day Sunday and Monday until 3pm. He was unloading in the cart that I was in when he came out of the combine in a big hurry. Said he smelled it again. Engine off at this point. He started looking in the area of the rwa, hoses, solenoid, so on. I opened the engine compartment and found puffs of smoke coming from the inside of the C channel of the rear engine main frame directly on the floor. The driver side is capped and have no access. one 1/2 hole under bell housing, smoking. The right side has partial access but smoke was coming out from under the c channel the length of the oil pan from a very small opening. Got some water and compressor to dowse the best we could but very little access. As we were blowing the channel out we noticed smoke coming from the ground next to left rear wheel. An ember had gotten blown out of the c channel, fell to the ground and started burning. Now we know where it came from but not what started it. We cleaned and blew water the best we could. Cut beans Tuesday, Wednesday, then switched to corn Thursday and Friday with no hint of smoke.
So my question, how do you prevent something like this, how did it start? I spend an hour or more, every morning blowing off machine, engine, radiator, filters, clutches, idlers. He can run the machine hard and the engine temp stays in the green. The radiator is clean, hyd oil not hot. Thought maybe filling channel with foam but that is also flammable.
Any thoughts?
Leon B MO
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 41 minutes ago at 9:02pm
Does your combine’s header use full poly skid plates?
Is your combine’s windshield constantly dirty?
If so, check out this video about static electricity onboard combine.
https://m.youtube.com/watch?v=J1sd5RL5jOA&pp=ygUiQ29tYmluZSBoYXJ2ZXN0IHN0YXRpYyBlbGVjdHJpY2l0eQ%3D%3D
Edited by AC7060IL - 21 hours 37 minutes ago at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 25 minutes ago at 4:18pm
We do have Polly under the sickle and we clean the windshield every day. But I don't ever remember touching the machine and getting a static shock. That is an interesting video though.
Leon B
cjarosz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjarosz Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 47 minutes ago at 4:56pm
My r50 was smoldering twice this fall I figured it was chaff coming out of processor the first time but next night same thing. Extremely dusty since beans died and not all the leaves were shed and dust coming from behind. Next day hung a chain from rear axle and not another minute’s problem I know dust on mine collects on the floor between processor and motor thought it was touching the exhaust and coming down but probably more from bouncing but chain seems to have worked btw head does have poly on it, first head with it I’ve had
