R52 reel speed problem
sodfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sodfarmer Quote  Post ReplyReply Direct Link To This Post Topic: R52 reel speed problem
    Posted: 03 Oct 2019 at 7:18pm
I have a 1992 R52. I am having a problem keeping the reel speed constant. I usually run in manual, but it doesn't work right in auto either. I get it set where I want it and it speeds up on its own.
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 9:41pm
The trouble I found with mine was the electric solenoid valve wasn't holding its position. Located on mine is under cab stairs. This maybe the trouble with yours!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sodfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:56pm
I took the coil off and put it back on and it worked fine yesterday. What did you do to fix yours.
This page was generated in 0.313 seconds.
