Question on Transmission / Hydraulic oil D-10
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Question on Transmission / Hydraulic oil D-10
    Posted: 13 Aug 2018 at 2:55pm
Question concerning the correct oil to use in the rear end of a D-10 Series II for the transmission and hydraulics.  Operating instructions manual say " Use non-foaming oil.  Use S.A.E. 10w-30 for all temperatures".    To me this is saying non-detergent, but typically you only ever see non-detergent as a single weight oil, as for example either SAE20 or SAE30.  Then there is the universal transmission/hydraulics oils like the TSC Traveller Premium Universal Tractor Trans/Hydraulic Fluid.  Kinda stuck on which direction to go on this one.  Sorry if this has been discussed before as a search on the forum didn't come up with an answer
snowman(MI)
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 3:05pm
I use SAE 20 non-detergent in my CA.  It is very similar to your D-10, just older.
Others will chime in I'm sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 5:55pm
I just use universal hytran, on both my 10 and 12...
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 9:28pm
I use the type you mentioned in my D10. TSC universal Trans/Hydraulic fluid. I use it in all my tractors. It makes it simpler.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 9:41pm
Same. TSC Universal Hydraulic oil, the stuff in the black jug, NOT the yellow one, in all 3 tractors and my backhoe. Ive done this for years and so far so good.
