Question on 8030 Rear End Fill Tube |
nowaktj
Joined: 13 Dec 2009 Location: Elk River, MN Points: 735 |
Topic: Question on 8030 Rear End Fill TubePosted: 01 Nov 2016 at 1:52pm |
Hi-Does anyone know what retains this tube? Mine is loose but I don't see how to remove it. Is it retained with an oring somehow?
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Posted: 01 Nov 2016 at 3:08pm |
Clean the tubes end and the housing bore with brake kleen and let dry. Red Loctite liberally spread and let dry overnite.
MACK
Posted: 01 Nov 2016 at 8:07pm |
Before you lactate, find a socket with some taper and drive in tube to swell it, then do as Dr. Says. MACK
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12324 |
Posted: 02 Nov 2016 at 6:27am |
Yeah! Definitely do as Mack says. You don't want to get all excited and lactate!!! HAHAHAHAHA!!!!
*sorry MACK* I totally don't mean that to pick on you. I just thought that was hilarious!!!! |
