pulling this weekend |
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Jun 2012 at 11:47am |
my 57 WD45. wondering if I might rty moving the wheels out a little? would this do any good?
German Shepherd dad
mlpankey ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
I personally think its better to run the wheels in narrowing the rear end as much as possible . This is the reason I never ran fenders to couldnt fasten them for the tire .
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8339 |
I always try to set the wheels out a little, if u look at others they are always about the same ;; moving out gets u in a different track
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
I pulled my IHC "C" once, my uncle said that with the wheels all the way out, the spring of the axels would help you pull more, so I put my wheels all the way out, we were pulling on concrete, dead weight. A friend brought his IHC "C" with it's wheels all the way in. I asked him why, he said he figured that way the wheels would be inside the burned rubber on the track that others had left on the concrete. I beat him and got second place. A Supper C beat me.
Dusty
with any luck we will be pulling in damp clay
German Shepherd dad
is the track level all the way across or crowned. |
Depends on whether or not they bring in more dirt
German Shepherd dad
Rod B ![]() Orange Level ![]() Joined: 25 Jul 2011 Location: Peoria Points: 415 |
narrow is going to be better. Most places will require fenders, but I suppose if you can't go verry fast than one could run without them.
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Most Farmall or JD's don't have fenders around here.
I set mine in as close as I can. The antique pull guide has some info on the science of it.
Charlie
theyre required if they were standard equipment. Back in the early Farmall and John Deere days fenders were an option.
German Shepherd dad
