PTO to drawbar specs
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: PTO to drawbar specs
    Posted: 13 Aug 2016 at 11:07pm
Isn't there a standard for PTO to drawbar dimensions? The PTO shaft should be X inches above the drawbar and X inches in front of the drawbar hole?
Putting a PTO on the WC. The shaft winds up where it winds up, the length and height of the drawbar is where I can adapt.
Thanks in advance.
The mechanic always wins.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 11:08pm
For an All-Crop there are suggested dimensions, and it works 100% better if you're in spec. Been there, done that! Big smile
What do you plan on running?
Edited by CrestonM - 13 Aug 2016 at 11:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 11:12pm
Anything and everything I can get my hands on!
But for starters, we use a 5' brush hog and a flail chopper somewhat regularly.
An All Crop? Someday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 11:31pm
Well, I found it in the manual after all. Says 20 3/4" high, and 8 7/8" to 16 3/8" ahead of hitch point.
Guess next time I'm out at Pa's place, I'll measure the WD. Everything works good with that setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2016 at 11:21pm
What you're after is the two joints running at the same angle when turning.After 30yrs I shortened the drawbar on my 45 and got the Woods 72 to all but quit knocking when turning.The decal on the pto shield gives demensions but it is WRONG!!
