pto locked up on CA
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Topic: pto locked up on CA
    Posted: 01 Jun 2019 at 7:56pm
Recently purchased a Ca wasnt running. Got it running and the PTO seems to be locked up, Any suggestions
phil
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 11:04pm
Pull the hydraulic pump loose, see if that helps ? Rusted plungers ?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 9:48am
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 5:47pm
the ca that i got going a couple yrs ago developed a similar problem, mine seems to be the bearing in the belt pulley. Also that oil pump I got from you did excellent!! She makes great oil pressure, thanks, keith so va
