Pros and Cons of corn pickers
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Pros and Cons of corn pickers
    Posted: Yesterday at 6:37pm
Looking to purchase a 2 row mounted corn picker.
Ill be picking less than 5 acres each year....
My disire is to have a D17 gas tractor under a 190 model corn picker....
My second choice would be a D17 with New Idea mounted picker....
What is your thoughts fellas....
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:01pm
Storage of ear corn is a con if you’re not set up for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:48pm
That's not an issue...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:24pm
Pick your poison. There would be 10 times (or more) New Idea's to find used parts for. The Allis would have the benefit of stripper plates.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:30pm
We had a New Idea mounted on an Oliver 880 when I was growing up.
Later we had a self propelled Case combine, open station!
"In the weeds" always sat the two row pull behind picker. Never knew why it was parked, and especially not used when the Oliver broke the fancy helical gear set first used on the 880 to cut trans whine.
Homesteading or smaller farm I'd try to locate a pull behind picker. Easy to hitch and go.
Mounted pickers are great for "opening a field up" in the outer rows. But those outer rows are eaten by deer and poor yield because of grass and trees. I'd plant a cover mix band around the field and use a pull behind picker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:54pm
Grew up on a single row New Idea picker. I admit the mounted 2 row pickers are neat but I can see where they would be quite noisy and dirty to run. Although compact compared to a pull type, the pull type are easier to work on and don’t tie up a tractor for a length of time. Most that were mounted, stayed on that tractor due to difficulty on mounting and unmounting. Wish dad had went to a 2 row picker but a single row kept us busy unloading a wagon one scoop at a time into the elevator to the corn crib. Good times…gravity wagons were to come years later lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 31 minutes ago at 12:18am
How about a Uni-Harvester? Neighbor had a 4 row unit.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 1 minutes ago at 6:48am
I pick 10 to 15 acres per year with an old style mounted ac picker over a wd 45. It never comes off. You will really put a work on the hand clutch if you get anything over 150 bu corn. Not as dirty and loud as some people say but it is my favorite thing to do so i may be prejudice. You have to plant wide(36 inch) rows if you plan on using a mounted picker. When i was a young man i picked corn with an ih 450 and a two row mounted 234 picker. Not a fan of the red paint but that machine was a beast!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 52 minutes ago at 7:57am
In the world of mounted corn-pickers, the 234 is king! They are easy on/off too, especially if on a Fast-Hitch tractor. Don't think I've ever seen an Allis 170 or 190 in action.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 54 minutes ago at 8:55am
If you only have 5 acres, a 1 row New Idea is all you need. Fairly cheap and parts are mostly available. But, if you want to suffocate in dust and dirt, then a 2-row mounted is what you need.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 9 minutes ago at 10:40am
There are definite pro’s and con’s to picking corn vs shelling(combining) corn.
Horsepower requirements for each can differ greatly. Storage of the harvested crop also differs. Labor required for ‘post harvest(storage)’ handling can be significant.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 56 minutes ago at 10:53am
Being old, I grew up in the era before shelling in the field.  Shelling was done by a local guy with JD Sheller mounted on the truck chassis.  He made the rounds, and it was a labor-intensive workday.  Trucks were mostly just 2/2 1/2 ton with a combo grain-livestock bed.  Occasionally a tandem with a bigger grain box.  Even back then, fire was a hazard.  Mostly from exhaust on sheller truck & husks everyone.  Had one fire that I recall & it was quickly doused.  Shellers were mostly JD with an occasional rare Moline.  Those were the days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 46 minutes ago at 7:03pm
I was surprised to see corn seed harvesting uses modern combines that pick ears. They store ears until the start of the year to shell, sort, clean, bag at the facility.
I had assumed they shelled in the field like all the modern combines. Apparently the cob is a good seed performance enhancer.
The other large modern ear picking I saw was at the Missouri Meersheim Corn Cob Pipe company.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 40 minutes ago at 7:09pm
No need to dry cob corn for storage if it reaches a reasonably level not sure what's recommended any more. Just a guess maybe 20% for cribbing. Cattle seem to like and do well with ground cob corn.
