Proper wheel mounting "B" |
dad2many ![]() Silver Level ![]() Joined: 19 Jun 2011 Location: NC Points: 104 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jan 2012 at 9:13pm |
OK, so I finally got the tire changed to the new rim and mounted back on my tractor. I'm not sure its right though. I have seen clamp blocks on the outside of the rim and the inside. I put them back on the inside as I found it and matches the other side. Also, I noticed that two of the bolts and blocks are eccentric. What is the proper way to mount and where are the eccentric clamps supposed to be located?
On another note, i found the previous owner had been running that hub loose and has worn out the hub splines. Anyone know what I can expect to pay for a good hub?
Thanks
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
there are guys on here that will give you advice on the hub. I believe that you remove some metal in the back of the hub to allow the wheel to slidr back further.
On the wheel mounting, 2 lugs are rigid and 2 are eccentrics. One of the solid lugs gets engaged between the 2 blocks on the wheel to lock it, the second one gets mounted in the next hole position, so they are side by side. The eccentrics go into the remaining holes. I always put the 2 solid lugs at the top, and hang the rim on them, then slide the bottom into place and install the eccentrics. Bob
I was contemplating grinding the back down to allow more drawup but some of the splines are less than half the original.
Its not a good feeling to hear that clunk on take off.
HagerAC ![]() Orange Level ![]() ![]() Joined: 14 Sep 2010 Location: SE MN Points: 1195 |
We just did a B with the same problem here. I believe we paid $100 for a good wheel center and $50 or $60 for an axle. Doesn't pay to do one without the other.
allisnut ![]() Silver Level ![]() ![]() Joined: 03 Dec 2010 Location: pa Points: 131 |
Hi What part of PA are you in I should have a good hub and a couple of centers for sale
let me know Thanks Phil
