Problem with a D-14 loader with PTO hydraulic pump
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: Problem with a D-14 loader with PTO hydraulic pump
    Posted: 31 May 2019 at 8:12pm
I had a guy stop in, hoping I would be able to help him with his D-14 loader (I have no clue...) . He says the loader has orange paint like the original paint on the tractor. It is a fully hydraulic loader with a PTO mounted hydraulic pump. The loader has a square metal frame and dumps hydraulically, not the tubing frame with loader, with trip bucket,  that I've seen on some D-14's.
His question is where to add hydraulic fluid. There is a plug, that looks like a vent on the side of the loader. (Sorry that I'm not doing very well describing it, but I have never seen the tractor.) He has tried adding hydraulic fluid through this "vent", but it blows it out when he raises/lowers the loader. He says he can't find any other place to fill the hydraulic system for the rear mounted pump. He also says the loader raises with jerks, which I presume is from being low on fluid.
Does anyone have any experience with a setup like this?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 8:29pm
Jerking is an indication of air in the system. The fill/vent should be near the top of the frame. There is usually a full level plug lower on the frame. If it blows out the fill it is too full or a lot of air in the lines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 4:44pm
Does anyone have a picture of a loader similar to what I described, along with where hydraulic oil should be added? Is there a way to purge the air out of the system without blowing oil out the vent?
If it's easier, you can email pictures to to me at curt12914@yahoo.com
Edited by WF owner - 01 Jun 2019 at 4:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 7:17pm
The old Char Lynn PTO pumps were there own reservoir.
https://i.ebayimg.com/thumbs/images/g/vggAAOSwknJX1zdt/s-l225.jpg
