Power steering fluid
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Topic: Power steering fluid
    Posted: 21 Jul 2023 at 11:22am
What is the correct power steering fluid for D-15, series 1?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2023 at 11:47am
I like using synthetic 10W 30 engine oil in my D14 power steering, much because of our cold winters. My power steering has improved immensely from a leak by using Lucas power steering stop leak additive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2023 at 12:50pm
you can use Power Steering fluid from the Auto Store... Or older versions of Automatic Trans Fluid Type A, F, Dextron 1-2-3 ..( I would not use the new MERCON LV or other synthetic with too many addatives- might effect old seals)..... or you can use Universal tractor Fluid ( UTF)..
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2023 at 1:29pm
I put 10W-30 in my series 1 D17. Have also drained and used Universal hydraulic fluid to see which worked best. Both work fine. Series II went to transmission fluid as Steve stated.
Edited by AC720Man - 21 Jul 2023 at 1:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2023 at 4:32pm
Original owners manual stated 5W20, Non detergent.  IIRR...Wink
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2023 at 8:39pm
ATF or hydraulic fluid.  ATF is better in cold weather, but will leak if your seals are weak because the oil is thinner.
I run ATF in all of mine.  No problems - all my seals are good.
This page was generated in 0.563 seconds.
