power steering booster
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: power steering booster
    Posted: 21 Oct 2011 at 5:28pm
Does anyone know if you how to remove the power steering booster to replace the o-ring on the back side of it?  1966 d-17 IV.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 5:31pm
I don't know what you mean by the "booster", but most everything on a 17 is serviceable so I would guess yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 5:35pm
Sorry,  i mean the power steering ram.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 5:51pm
Yes, it's repairable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 5:57pm
With out removing from tractor?
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 6:00pm
No.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 6:09pm
Drain the coolant,  Drain power steering fluid,Remove the front sheetmetal and radiator, , support the tractor, and disconnect the lines necessary to remove the front bolster to clear the front motor mount. Once the bolster is clear you can pull the ram and do your repairs.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 8:30pm
You will have to remove the plate on left side with 4 allen head bolts to get rack out then will have to be timed back .   MACK
This page was generated in 0.281 seconds.
