Power shift for pulling? |
Author | |||
Mattman ![]() Silver Level ![]() Joined: 20 Dec 2012 Location: Plover, WI Points: 224 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Aug 2024 at 6:50am |
I have a power director 7040 and love it. I'm looking at a power shift 7040 tractor to make into a puller. Is this a mistake? Should I be looking for a power director to pull with? By the way, I cant pull with my current 7040 as it is a low hour family heirloom. Thanks everyone.
Sponsored Links | |||
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21467 |
HOW MANY HP ARE YOU INTENDING TO RUN ??
No more than 220 horses
Power Shift is fine, but less speed choices.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4952 |
Many have pulled with Power-Shift-Transmissions. I've even done it myself. However once you get into it are you absolutely sure you will never decide to go faster with more HP? With that in mind I'd be looking for a gear drive instead of a Power-Shift. With my hands on experience in high HP pullers NEVER downshift with a Power-Shift. Find out what gear you can handle and never go any higher than that.
bigal121892 ![]() Orange Level ![]() Joined: 05 Jan 2010 Location: Nebraska Points: 808 |
Why don't you downshift?
Edited by bigal121892 - 26 Aug 2024 at 2:52pm |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8266 |
Well in my past experience with a Power Director- some shifts can be smooth some not- you.ve got tons of weight behind you- then changing the inertia of everything - can work out but sends shock thru the drivetrain,, Powershifts have to be tight ; just my opinion now
Things don't happen when upshifting, however from PRESONAL experience with HIGH HP pulling, downshifting is when things break.
Edited by PaulB - 26 Aug 2024 at 6:45pm |
Thanks for the reply. I have never pulled, and assumed it was something like that, but you know what assuming gets you. :)
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5074 |
the downshift isn't quick enough for sled pulling, my 7040 PD that I pull on occasion is fine to shift up at start of pull, but have tried downshift at end and it stops, then takes off again, very abrupt, so I just quit using it to downshift. I think mods have been done to them to make them shift quicker, but mine is all original in the PD section.
The speed with which the clutch packs release and engage has to be quickened up as the HP increases. 220 HP isn't an issue but 400 HP sure would be.
Joe(OH) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 991 |
A cousin of mine was at a tractor pull in the '70s after Allis came out with a power shift transmission. There was one pulling and he up shifted and down shifted. The announcer made the comment " That tractors got more gears than Carters got liver pills!" I dont know what year or how the tractor did, but thought it was a funny story.
Life is simpler when you plow around the stump.
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 8253 |
That was a wonderfully hook !!! Did you raise the power shift regulating pressure any ??
The Allis 12-speed Power Shift should look pretty good in classes where your top speed will never be above 6MPH. When in LOW range your speeds are 1 MPH apart from 5th on down and are pretty nice clean/smooth shifts. Where the Allis tranny wouldn't look good is where you are expecting ground speeds of over 6 MPH as the spread between gear selections becomes quite wide.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8634 |
Is that you pulling Tom
No, just the torque limiter was beefed up.
Nope, brother always pulls that one, wife is in second one though.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3499 |
