Power director delete for 200 |
Post Reply |
200puller
Bronze Level Joined: 28 Aug 2021 Location: Edinburg va Points: 3 |
Posted: 28 Aug 2021 at 4:39pm |
Is there any way to delete the power director from a 200 found out it was my problem with slipping and wondering if there is a gearbox to do away with this problem thanks in advance
brad durst
Bronze Level Joined: 20 Aug 2018 Location: richland center Points: 85 |
dennis at fvp has a manual shift couplers that he had made. works well thats where i got mine
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
Id be interested in how this is done - pics would be great
brad durst
i never took pictures. i can if i have it apart again. its basically the same as years ago when they would take the power director apart and use nickel rod and weld the two gears together you have to machine the outer hollow shaft tho. the ones dennis has are made out of billet. i think there are pictures on face book on the allis pullers sight. i thought i took pictures but if i did i cant find them. my buddy has been running his for a couple years now.
DougG
Ok thanks for the info
KevinON
Orange Level Joined: 07 Dec 2009 Location: Schomberg, ON Points: 786 |
So can you still shift with this set up? I mean shift manually when stopped?
brad durst
yes it is a manual shifting coupler that can only be shifted with the engine off
DougG
Like some pictures !
brad durst
DougG
Hey thats neat, thanks
estout81
Bronze Level Joined: 15 Mar 2022 Location: Utica Ohio Points: 34 |
I made a power director delete back in the late '70's that worked well. Would post pictures if I new how but, I' new to this forum.
DougG
Youll figure it out - keep trying
estout81
estout81
DougG
Looks great! Let's hear some history on this design!
estout81
Doug G, I designed and built this unit back in 1976, I think. Gettin' old and can't remember! It was an 180 that I built for a local farmer. He called it "Little Allis. Won state and national championship in I think 1978. If you look at the front end you will see a modified Oliver 60 front end. Later had to make a wide front due to rule changes. I was also the first to put a Bosch inline pump in place of the rosamaster in the stock location. The power director shifter is a sore subject for me. That's another story! Em
DougG
Wow! Very nice! Thanks for the info! Bet that 301 was singing a nice tune!
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6516 |
Inside splines, nobody around here locally can do them. Looks nice.
DougG
Emerson, what was you guys using for the engine clutch back then ?
Post Reply | |
