Power Adjust Eccentric Snap Rings
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: Power Adjust Eccentric Snap Rings
    Posted: 17 May 2012 at 1:30am
Am working on my WD45 and need a bit of help locating a part. It's been a  while since I posted on here, but I am hoping that one of you has a better memory than do I!
A (longish) whlle ago, I recall seeing one or two sources for the snap rings that secure the eccentric into the Power Adjust locks. Haven't been able to locate the right thread. I also (dimly) recall that one source was what used to be Dean Ag, now Ziegler Equipment. Does this ring any bells with anyone?
Thanks for the help!
WC, CA, D14, WD45
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 5:37am
I have made some from the appropriate size coil spring.
Just cut down the spring lengthways with a disc grinder.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 6:19am
Thanks, Gary. I'll give that a try. As I recall, the rings ran about $10 each!
WC, CA, D14, WD45
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 8:43am
Dave   !!  PN is  70223201         Last i bought  from Dean ag --  Now  Zigler     1-12-09 were  $2.01  each  + shipping.    Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 12:13pm
Thanks, Tony. Much appreciated.
WC, CA, D14, WD45
