Plowing with the two 8070s
JOHN N/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOHN N/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 9:02pm
Dpower are those Plows series 2000 or 9000 i cant tell.
D-15IIG65,D-17IVG67,D-17D58,620
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 9:17pm
THey would be 2000 Series. We just started looking for parts for ours since they are getting worn. We had a 2000 5 bottom that we used for some parts. I see shoup has some parts too. I might have to visit you Wisconsin boys and get some parts. Dad just bought a really nice 2000 series 4 bottom that i plan to put with my 8010 FWA next year. THe 8000 series is a very nice tractor to run. Hope to put more weight on the 8070 PD and add another bottom to it to make it a six bottom.
7010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7010 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 9:47pm
I see you have the buster bars on these units.  They really make a nice addition to plows.  I grew up plowing with a 7000 and 4 bottom 2000 plow and buster bar, it really breaks up the lumps and saves trips with a disk later.  Nice machines, kind of jealous.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 10:21pm
Were white-wall car tires standard equipment on Allis plows?  *grin*  Our 4-16 9000 plow has a white-wall tail wheel also.  Nice looking rigs.  We're all no-till here, but there sure is something therapeutic about plowing - especially in a climate-controlled 8000 series with tunes on the radio!
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 10:43pm
russ i just bought a 8010, is yours a powershift?? The one i just bought is a 1985, two years ago they split it becaue it would slowly move forward in neutral  found some broke plates they spent over 7000 to get that fixd, Needs a new cab interior though. I know you really like urs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 10:48pm
Yes, powershift.  A little under-powered for it's weight (or overweight/overbuilt), especially when you consider that new 110 hp tractors are 4-5000 lbs lighter.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 10:48pm
Just thinking what would make a cool picture an 8010 with 4 bottom a 30 with 5 bottom a 50 with 6 bottom and 8070 with 7 bottom all lined up and heading across a field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 11:00pm
be cool to have the only 301 engined fwa model allis made
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 5:49am
Originally posted by SHAMELESS SHAMELESS wrote:
guess i've ruined my 5 btm and my 4 btm IH plows, they have hit stuff, making them trip, and i can't get em to go back into place! guess i'll just cut em up and go buy another...if i gits to farm again!
You'll have to take the beams and trips apart. I had to on my 2000 Monoframe. They wouldn't trip at all. You should be able to, with the plow in transport, lift the toggle and trip the bottom by hand if all is free and working right. It was quite a job to do to take all apart. Required heat and a BFH. Then my front bottom tripped all the time but it just took adding a washer under the toggle spring to cure that.
Wink
I am a Russian Bot
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 9:04am
good looking tractor, and plow rigs, i have been looking for a good set of 4 bottom plows for my 6060, but the best i have come up with so far is a 3 bottom set of fergusons model 82 high clearance, hoping to come up with the bolt on forth, like your tractors this 3x16 set is just a lite workout for the allis
i like old tractors of all colors
