Plow tires |
Rod in MN ![]() Silver Level ![]() Joined: 16 Sep 2009 Location: Rice MN Points: 290 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Sep 2018 at 2:51pm |
HI I have a 2 bottom plow and I was wondering what tires I should put on the stubble Wheel and on other front wheel the size is 6.00x16. where is a good place to get them?
Thank You Rod |
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
They have what's called a "traction implement" tire that I would put on the stubble wheel, basically like a miniature version of a rear tractor tire but the bars run backward. I would put a smooth implement tire on the furrow wheel and a single rib on the back if it has one. Miller Tire has a Firestone "Power Implement" tire and "Rib Implement" tire listed under 6.00-16 implement tires that would look period correct for your plow.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53724 |
You just mount the tire backwards(as compared to a rear tractor tire), on the rim, to make the traction tire work correctly...
acd17toy ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: USA Points: 708 |
Plow tires. if your plow has a rubber tired tail wheel , most run at a angle you should get the correct one as all others will not run with the full tread contacting the ground and could cause the plow not to trail rite.
