plow cross shaft removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: plow cross shaft removal
    Posted: 05 Dec 2011 at 10:04pm
I have the cross shaft and vertical  center plate with casting on each side setting on the floor. (3-14 span coupler plow).  Has a 1/2 inch square set screw in the  casting tight against the shat. I have the screw out and the castings and plate dont want to move on the shaft. Do they screw together or ???  Plate appears to be mounted between two castings and neither is moving.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 10:13pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 1:34am
Kroil, PB Blaster, or a 50/50 mix of acetone and atf accompanied by heat and shock. Let one of the penetration brews soak a while before getting noisy. To add to the tightness besides rust, its likely the set screw pushed up a bur in the hole.
Gerald J.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 7:07am
Just like Gerald said and then put the heat to it.  If you have a rosebud use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 5:03pm
Thanks guys, i just didnt want to start beating the crap out of it , if it was screwed or pinned somehow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:06pm
The parts pictures I looked at in my plow frames book showed only that set screw in the collar between plates, nothing for the cast flange with the three bolts through the plates. Though I could envision another set screw there in some versions. What model plow is it? That might affect the picture I should have looked at.
Gerald J.
