planter markers |
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2372 |
Topic: planter markersPosted: 22 May 2017 at 9:06am |
On my 333 the right hand marker slowly works its way down when the left hand marker is down. Would it be something in the switch valve or whatever its called causing this? There's no sign of leaks from the cylinder unless its completely internal.
tomNE
Joined: 13 Sep 2009 Location: dorchester, ne Points: 1225 |
Posted: 22 May 2017 at 3:50pm |
surplus center sell a flip flop valve. I have it on my 15ft drill. it works great and you can even figure out how to have both markers down at the same time.
AC from the start of my families farming career till the end!
Lester
Posted: 22 May 2017 at 4:00pm |
You use two way to speed it up lowering.
shameless dude
Posted: 22 May 2017 at 5:09pm |
I took the markers off my 6-30 years ago...don't need them.
MACK
Posted: 22 May 2017 at 9:17pm |
I use my GPS. MACK
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3551 |
Posted: 22 May 2017 at 10:17pm |
internal leak, most common. .pac it. Also the sequence valve could have a piece of trash or oring in it. Simple to check , pull allen plug and remove detent ball the the fittings to each marker and under each is a ball seat that can be examined , any mark on the steel ball will cause a leak.
grinder220
Posted: 23 May 2017 at 10:27am |
Thanks Tim, I'll check it out. I've been using it for 2 years without the markers but it would be nice to have them working again.
