PD/TA ? |
| Author | |||
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: PD/TA ?Posted: 31 May 2020 at 8:24pm |
Are the power directors in Allis tractors similar to the torque amplifiers in IH tractors ? I realize the ta's don't have a neutral position, but otherwise do they do the same function ?
Seems like the ta's get repaired/replaced/"locked-up" somewhat often .
| Sponsored Links | |||
MACK
Posted: 31 May 2020 at 8:59pm |
Nothing a like. PD IS two sets of wet clutches with gear reduction ahead of them.
TA is a planetary with a spray clutch. MACK |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 31 May 2020 at 10:07pm |
Power directors were far more reliable than the TAs!
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 01 Jun 2020 at 6:20am |
TA = TroubleAhead. If a Torque Amplifier isn't broke, it soon will be. Many TAs will coast downhill. A Power-Director is a positive drive in both ranges.
TimNearFortWorth
Posted: 01 Jun 2020 at 7:37am |
There was a reason for the saying "every time you throw the T/A handle, put a dollar in a coffee can cuz yer gonna need it to fix it sooner than later".
Still plenty of them in use, albeit locked in low so the tractor can still be used without the major expense for tear down/rebuild. Have known some to still run hard for years after locking them in low side, after they had them rebuilt once or twice.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 01 Jun 2020 at 7:41am |
Agreed. While in college, the Farmer I helped during spring plantings had only one thing to say about his IH 806 on the disk, “Put it in gear & LEAVE the TA alone!”
Technically, that’s two things :) AC’s PD took punishment- ie roto baler! Edited by AC7060IL - 01 Jun 2020 at 7:45am |
FREEDGUY
Posted: 01 Jun 2020 at 5:12pm |
That brings up another question, were the WD/D series a "wet" or "dry" clutch set-up (P/D) ?? Mack made a statement about "wet clutches", but I assumed this was for the "hundred" series ??
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 03 Jun 2020 at 11:44am |
Really? Apparently you haven't read any post in the past about WD Through D series hand clutches. The answer is there.
AC7060IL
Posted: 03 Jun 2020 at 12:21pm |
WD & WD45 had a “2 clutch power control” (foot & hand clutches). The foot clutch operated an engine dry clutch that engaged/disengaged everthing(trans/pto/hydraulics). Their hand controlled clutch ran in oil & only engaged/disengaged trans, allowing pto& hydraulics to continue operation.
The D series’ had a similar setup except it’s hand operated clutch became the 2 speed “power director” (high & low “stick PD”). It too ran in oil. The 100 series (not 160)also carried the 2 speed PD which also ran in oil. But the 200,One-Ninety,One-Eighty, & 185 PD was hydraulically operated vs the hand “stick” control on the One-Seventy,170,175’s PD. Edited by AC7060IL - 04 Jun 2020 at 9:51am |
FREEDGUY
Posted: 03 Jun 2020 at 6:11pm |
