Painting woes
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: Painting woes
    Posted: 03 Sep 2019 at 9:45pm
If I'm going to paint an entire tractor, I've got to get a lot better. With the prep, primer, and painting three times, I spent the better part of five days on this one hood.
I got the tent idea from Sugarmaker. The results were mixed. Less wind and fewer bugs, space was a problem. Light was ok, but not as good as outside.
I had a lot of trouble with my paint. I got a quart from the New Holland dealer. They said it was ready to spray. I never could get to lay down smooth, no matter how I tried to adjust my gun. It looked rough dumpy and textured. I took it up the road to a little body shop and asked for some advice. They said it looked like it needed some reducer. I said it was supposed to be ready to spray. They said it may still need reducer. IMO if it needs reducer, it's not ready to spray. Nevertheless, I sanded the hood down and painted it again with reducer in the paint. It was much better, but not good. Plus I got a big run in it the second time. So I sanded it down again and decided to put the spray gun away. The 3rd painting I used three cans of this.
The problem rattle cans on something this large is the spray fan is to small. It went down smooth and looked ok, but I had some light and dark streaks and some orange peal in places. You can't really see it in this photo but it's there.
A guy at work said I should wet sand it. I never done that before, but I watched a few youtube videos on it and gave it a try. I have to say I was pretty pleased with the results. The wet sanding blended the streaks very well. A lot of polish and two coats of wax and the old girl looks good enough for me.
It's still not what I would call a professional job, but I'm happy with it. It just took to long and more work than necessary. I'm not sure if it was the paint, my gun, the hot weather, or just me. I'm going to go back to the PPG paint on my next job. It was easier to work with, I think it's worth it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 4:39am
Problem (usually) with rattle cans is there is no hardener in it.  Usually shows up as chip out, later...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 5:40am
re: Krylon... the tapered top cans are low VOC paint, square tops are 'old skool' ie: real good paint. This from the Krylon guy at HQ, told me this when I said it wasn't covering like before.......
I've stopped buying it, gone to Rustoleum at $5 a can up here. GREAT coverage,goes on smooth, dries fast. Just time it right(read the label...) and put 2-3-4 coats on then let it harden overnight BEFORE turning wrenches.
Using any 'auto type' spray paint takes a lot of time and patience to 'dial in' and get everything correct. Heat,humidity, pressure,distance, technique. The pros make it look easy since they do it everyday.......
I still use a brush to paint enamel onto rider decks and trailers, no runs...
Jay
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 6:44am
Interesting post . I use Rust-Oleum implement spray paint on my D 15 . Looks good to me . Never painted anything as big as a hood though . Thanks
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 6:45am
i think you are on the right track to next time go to the PPG dealer.   From start to finish whatever you put on has to work together as a system.   Becuz I am no "expert" I go to the PPG store and tell them what I intend to paint and ask what I need.  Example there are about three diferent drying speed reducers for different temps.  Also read the directions on the can some will need sanding between coats especially if time is more than 24 hrs between coats etc.  HTH Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 9:03am
Ranse,
 I think you did real good. But following anything I do will probably get you in trouble!:) I always think that I can paint but the paint has a whole different idea. Like about anything the pros make it look real easy! I think your hood turned out real good! Looks "factory" to me! Thanks for the tip on the blue I worked all day on a much smaller, much older, blue tractor. Debating about the paint. I love rattle cans for the convenience factor. I do not like how it dries and or top coating with automotive paint can give many mixed results.
I may try PPG paints if I ever do another large project?
Paint booth would be great to help control the finishing environment during paint. I dont have one. You only need it for about 1/10 of the total time to do the item.
I think your doing well and thanks for sharing your techniques.
I wet sanded a lot of panels when I did our 55 Ford years ago. I have not wet sanded much on these tractors. I am probably getting finishes similar to what they got in the factory. Mine could always be better and I am always tough on my finished work!
Continue to improve is the best we can do!
I need to go get some Krylon primer too. Have a panel on the truck to repair.
Edited by Sugarmaker - 04 Sep 2019 at 9:06am
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 10:40am
get some plastic staple to your rafters, hang you parts from the rafters with safety wire, put a couple furnace filters in on end and a big box fan blowing out on the other end. wet the floor and use a cheep HVLP gun I got mine at Menards. set a large piece of card board next to one of your plastic walls and set your sprayer coverage using it. make sure you use the correct mask for the type your spraying. I've been using Valspar one gallon pain 1 quart reducer 1 pint hardener. you should get a flow meter. it a little funnel with a calibrated hole. takes 10 seconds for a full cup to drain out. always thin your paint to the same  consistency every time.
Edited by Dakota Dave - 04 Sep 2019 at 10:41am
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 11:52am
I smuggle my paint in from free America the paint in CA is worthless.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 12:10pm
From the photos it looks good. And if your happy with it even better. An ad for automotive paints say the key to a good finish is ninety five percent prep and five percent paint. As noted the reducer in many cases is temperature sensitive. As well as humidity. Also you did not say if you sanded between coats. I have either wet sanded the primer with 400 grit or dry with 320. The color coat will reveal the surface through the paint when dry so a smooth primer surface is important. As with any skill, practice practice practice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 8:12pm
I appreciate all the comments guys. I admit I got frustrated with my painting and resorted to rattle cans. I won't apologize for it because I'm happy with the paint job right now. Maybe by the time it starts to peal and flake I won't care as much as I do now, hopefully.
I confess I like to vent on this forum from time to time. My gripe is the guys at the dealership told me the paint I bought was ready to spray. I had doubts the moment I opened the can. It looked as thick as house paint. No way it was ready to spray, but yet I tried it anyway because that's what they told me. I learned two things from this project. One, get paint advice from people who know paint. Not people from a tractor store. The other is the beauty of wet sanding. Now I know if you screw up, it's not necessarily a do over.
BTW; The paint I got from the dealership was Valspar acrylic enamel factory approved 1963-1999. Color wise, the Krylon Ford blue was almost a perfect match, almost. The only way I could tell a difference is to spray some of the Krylon on a piece of metal I already painted with the Valspar. I thought I would throw that in for what it's worth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 9:21pm
Spray out a test panel is a good idea. You can compare colors side by side as well as check your spray pattern from the rattle can or gun. That way you get to make adjustments before actually painting your project
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 4:54am
I recently had my local AGCO dealer order me some Persian Orange (79023273 Qt. Low V.O.C.) AGCO (Valspar) paint.
When I asked the dealer to order the hardener, there is a minimum order quantity of six and it was almost $80 each. I didn't want six ! I was able to order the correct thinner and hardener from a John Deere online store (https://www.greenpartstore.com/search.asp?keyword=renew+paint+hardener)
The  following was copied and pasted from the ACGO Paint PDF:
8:1:1 (Paint: AGCO Thinner: Renew Hardener Part No. 79022595)
Spray Application: Reduce with AGCO Thinner up to 8:1, reduction may vary with types of equipment and atmospheric conditions. Spray a mist or tack coat, followed by a full wet coat to avoid runs and sags. Start at the top of equipment and work down to eliminate dry spray which dulls the finish.
There is a lot of info on the PDF.
Edited by WF owner - 05 Sep 2019 at 5:01am
