Paint technique |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: Paint techniquePosted: 15 Sep 2016 at 6:29am |
After doing a few tractors, what is your best technique for doing the bottom of the tractor?
I have a top fed gravity HVLP gun and it is hard to manage laying on my back. Use a smaller gun?
Charlie
Butch(OH)
Posted: 15 Sep 2016 at 6:53am |
I use the same setup and manage to get mine covered well enough. The trick is to paint underneath when the cup is full and when it becomes hard to keep paint going to the tip you finish out the cup painting on the sides. If you actually want it too look as nice up side down and as it does right side up I suggest turning it upside down to paint the bottom of it ![]() |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 15 Sep 2016 at 7:45am |
Ok...my guilty moment...when I painted my 8N, I had the same problem, so I figured "No one looks underneath anyway", so I just brushed the paint on underneath.
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 15 Sep 2016 at 7:48am |
Chain Hoist up the front as high as you dare and get after the bottom of it with the gun you have. Your cats and dogs really do appreciate a nice paint job on the bottom of tractors.
Charlie175
Posted: 15 Sep 2016 at 8:04am |
My cousin never fails to come look at a tractor and loves to point out any issues....
Charlie
Bob-Maine
Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
Posted: 15 Sep 2016 at 8:28am |
I learned that you can never have enough light when you paint. I will use several
"clamp lights" to illuminate the work when I paint the next one. Bob@allisdowneast |
I used to think I was indecisive, but now I'm not sure.
lockheedt33
Joined: 05 Sep 2011 Location: Waterman, IL Points: 125 |
Posted: 15 Sep 2016 at 12:07pm |
The best way to do it is get a 3m pps adapter for your gun and use the pps system. It's got a cup with a collapsible plastic liner. You fill it with paint, put it on the gun, turn the gun upside down and spray until it sucks all the air out of the liner and then your gravity gun will spray in any position. The cup liners are disposable so there's a cost there but I've found it's pretty much break even at the price of solvent for cleanup anymore. With the pps I might use 1/4 to 1/2 pint of solvent to clean the gun.
1941 AC B
1948 AC C 1951 AC CA 1954 AC WD45 |
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 15 Sep 2016 at 9:17pm |
Lockheed 33 explain a little more if you will about the gun.i would like to get something like that...oh by the way how was you associated with the t bird ?had one in base op in west texas,fine airplane.....
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 15 Sep 2016 at 10:59pm |
you should have never let that out Creston!
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 16 Sep 2016 at 2:51am |
My brother used his backhoe to pickup my d15 when he painted it so he had access to the underside standing it up vertically. The backhoe was a ford 555 so the over spray of po2 made it look better... if nothing else it is an excuse to buy a backhoe and I am sure we all need one of them....
