Owners Of 8000's
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: Owners Of 8000's
    Posted: 18 Apr 2019 at 8:26am
Check your fuel hoses between the diesel pump and the filter on the right side of the engine today. I am told this hose has to handle up to 90 psi at high idle with no load on the engine. The problem is the pressure is built and released several times each second. This hose gets worn in the clamps that hold it and against the engine block. Ours are going to be placed this spring. They look like they could burst any second.
  I have gotten new hose at Spencer Diesel in Spencer, Iowa. They have some that are 38" long and ours are 50". I bought bulk hose and will have ends put on.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 10:10am
don,t use hyd hose  has to be flex hose best to buy from agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 9:57pm
This stuff is not hydraulic hose. We tried to use one from AGCO. Would have needed to get different fittings and the hose ends made the hose twist about a half a turn when it was plumbed in.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 8:44am
   Why not hydraulic hose???
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 8:58am
The hose is supposed to be somewhat soft to absorb pulsations of injection, to keep from transmitting to a surge. Not as big an issue as on IH tractors with the M100 pump, but I'm sure it still is an issue. A very rigid hyd hose is just too hard, and can't act as an accumulator like the soft hose can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 10:58am
Agco shows that you need to also get the fitting I changed A lot of them that way
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 11:59am
Aha, thanks Ed.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 1:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 1:26pm
I've replaced that hose too...not sure if I bought it from Agco or just had one made?
It has to be from Agco?
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 2:54pm
If 90psi is all it gets you could use Aeroquip AQP hose. That stuff is tough and rates 200psi.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 2:57pm
Which hose in the diagram is the one that you guys are talking about? Wondering for myself and for people in the future that may search for this post.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 5:58pm
The hose with two clamps on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 10:45pm
So this applies only to the M100 factory setup? Different animal with my  Bosch A pump?
