otb - jd 4230 roosa master return fuel line boot |
cob_crusher
Joined: 20 Dec 2011 Location: locke, ny Points: 175 |
Topic: otb - jd 4230 roosa master return fuel line bootPosted: 23 Sep 2016 at 4:04pm |
have a jd 4230 diesel with roosa master return fuel line with rubber boot which is held in place by round o clamp with two legs. very tight clearance to work in. a radiator hose clamp plier does not really work that well as it opens one has to also push down to center over double ribs. if anyone knows what tool is, what part number and where to buy it would be greatly appreciated. local deere dealership is no help.
ac 200 7080 653 da d90.06 6265 f400 ol 77 1650 jd 4230. the reward of suffering is experience. ignorance is bliss. no muff too tuff. i am only responsible for everything. free whiskey naked women.
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 23 Sep 2016 at 4:28pm |
imagine that!
Michael V (NM)
Posted: 23 Sep 2016 at 7:08pm |
I'll try an get ya a picture of the pliers I used on my 4020,, they're to big to send with this phone, an I haven't figured out how to resize em
bigal121892
Posted: 23 Sep 2016 at 7:25pm |
Go to MicroMark.com, and look for a "spiking" pliers. I find these to be very useful, on these type of hose holders.
hillmonkey
Joined: 03 Apr 2010 Location: oville fl Points: 417 |
Posted: 23 Sep 2016 at 7:28pm |
if you have any of the snap ring pliers with the removable/interchangeable tips you can remove the tips and put the clamp ends into the slot.use the corresponding inside or out side type to match the direction you need for the clamp.
Michael V (NM)
Posted: 23 Sep 2016 at 8:22pm |
heres the pictures of the tool I use. I got this one off e-bay, I cant remember how I searched them though, might try 'hose clamp pliers'
![]() ![]() Edited by Michael V (NM) - 23 Sep 2016 at 8:23pm |
VAfarmboy
Posted: 24 Sep 2016 at 1:10am |
We have a JD 4230 too and I made my own tool. What I did was took a set of Sears Craftsman pliers and put them in the vice and drilled a hole through the end of them using a bit slightly larger than the diameter of the wire the o clamp is made of. The end result looks very much like the picture on the left that Micheal posted, except that the hole is round. I keep those pliers and a handful of those rubber boots and o clamps in the tool box of that tractor. Nothing like having one or more of those rubber boots bust loose and start spraying diesel fuel everywhere when you are working on the back 40 of a farm miles from home. Edited by VAfarmboy - 24 Sep 2016 at 1:19am |
