OT -- perkins a6.354 cav dpa pump -- injpumped |
cob_crusher
Joined: 20 Dec 2011 Location: locke, ny Points: 175 |
Topic: OT -- perkins a6.354 cav dpa pump -- injpumpedPosted: 04 Sep 2019 at 5:18pm |
put in new rear main seal, dual clutch discs & throwout bearing & new lift pump w/ sediment bowl in tractor that has not been started in 5 years & was stored inside. bled 2 fuel filters aok, bled inj pump body aok but noticed one fitting was a little loose so added pipe tape threads around base. op man says to crack cylinder 1 & 4 at base of injector (hi pressure). get no (zero) fuel. checked inj pump inlet screen & was aok. tapped lightly on inj pump body. still no fuel at injector. when injector top (overflow) loosened was fuel stream aok without air.
is pump gummed up & need rebuild ? thanks |
ac 200 7080 653 da d90.06 6265 f400 ol 77 1650 jd 4230. the reward of suffering is experience. ignorance is bliss. no muff too tuff. i am only responsible for everything. free whiskey naked women.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3127 |
Posted: 04 Sep 2019 at 6:23pm |
What tractor is this?
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5156 |
Posted: 04 Sep 2019 at 6:40pm |
very likely the plungers are stuck. CAV and Roosa pumps don't like sitting in old fuel very long.
cob_crusher
Posted: 04 Sep 2019 at 9:28pm |
massey ferguson 1100 diesel
