open center rims
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: open center rims
    Posted: 10 Jul 2022 at 6:54pm
I just noticed today that one valve stem is outside and the other one is on inside,shouldn't they be on inside.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2022 at 2:40pm
I prefer them with the stem outside. Unfortunately you need to remove the tire from the rim to change if you just flip the rim the tred will be backwards
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2022 at 5:56pm
who ever installed the tires did them both EXACTLY the same... If you moved the rim to the OTHER side, the tire valve would be on the outside.... Got to remember when installing tires to have one LEFT and one RIGHT... Not two LEFT.
