Oliver 550 steering parts
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Topic: Oliver 550 steering parts
    Posted: 08 Dec 2011 at 6:29am
Anyone know of a place that might have a steering box or internal parts for a steering box for an Oliver 550, non power steering ? Guy I know that has one says it won't turn to the left, thinks the worm gear and balls are wore out. I guess he had it apart years ago and they were bad then. I seem to remember seeing pix of the balls in a steering box before but don't remember what it was on.
Any help appreciated.
Warren
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2011 at 6:56am
Korves Bros over by Waterloo, IL are the best in the world. If you're looking for used, Ollie Schaffer at Greenville, IL. In PA try Landis Zimmerman although he does mostly crawlers.
Edited by John (C-IL) - 08 Dec 2011 at 6:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 7:37am
Bit of follow up, got the steering box back together yesterday, just needed the top bearing. Was fun fishing the rollers out of the steering box. It's good and clean now !
Got to noticing the spindles while testing the box, whole front end needs rebuilt now ! Can't see all the play when the weight is on it ! Gonna set it up to run the buzz saw and then pull it apart to see just what is in it. Book shows a bearing and a bushing !
Always something...
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 9:09am
http://www.agpartsfirst.com/
These guys are in Wooster Oh.  Lots of parts and lots of connections for Oliver/White/MM.  They also have alot of stuff for the Fiat built machines
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
